Tsar
- 1,084
- 4
- Sep 22, 2003
none,
Alabama
Just like the dude in the video said "holy fing sh*t"
hell yah, if its that easy. DRift here I come!FrostBite said:How hard is it to do this??? I am really considering making my awd rwd after seeing that.
J92EGSX said:it all started when my rear diff. started to take a crap, i knew it was going to go some day because of the clicking from the rear spider gears, anyway i decided to take one of my 15 trannys laying around and build a temporary rwd tranny to blow up my rear diff. So i took my tranny apart and welded one side of the center diff, took out the viscous coupling and took out 2 of the spider gears and the one side gear that drove the front diff. i also ended taking out the front diff. (not nesscary). put all that back together and used two frost plugs to block off the front axle holes in the tranny case and put stub shafts threw the front wheel bearing to hold the preload on the bearings. Then i called my friend and told him to grab the camera and lets go blow up my rear diff. so anyways it lasted about a week. it was damn fun until i had to tow it home!
anmsk8r said:I would like to know if theres a way to convert my 93 talon tsi AWD to RWD. Can u undo the front axle or something? or is their something i can buy such as the WRX STI's have where you can switch between AWD and RWD? any help is appreciated.
