AWD swapped FWD
bOOst JuNKy
88
Aug 17, 2010
Haverstraw, New York
Just want some input from fellow tuners. Im intrested in buying a car i found, it is a gst converted to a gsx. Should i be worried about the car or should i go ahead and buy it. The car looks mint in and out, the only dsm i ever seen in this good of condition and only had about 70,000 miles. I would be the forth owner if i went ahead and bought it. Im pretty sure it was done by a professional. Should i go ahead with the buy?? Help me out tuners.
pics...? mods...? something. How you can you expect some one to tell you whether to buy it if they have no idea what it even looks like or how it runs and drives
Well... as long as they did it the right way, and not the honda way, I don't see any problem with it. as far as I know it all bolts in, minus a bit of fabrication.
get under the car and cross reference what you see versus the GST>GSX writeup (cant find the link right now).
agree print out the write up so you know what is involved and then check the car out yourself.
Write up is found at VFAQ.com under dsm-drivetrain. Jay has put a lot of work into his write up and it shows.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
