awd swap
There is a lot of work with that conversion. You are not just going to pull your F5M33 and drop a W5M33 in there and call it a day. You will need a gas tank, driveline, complete AWD exhaust, sub-frame, LSD, 1/2 shafts, wheel speed sensors (If you want ABS), possibly have to rewire the gas tank ect.
I would check out a few of the many threads that has covered this so you know what you are getting yourself into.
Yes, any 2g DSM will convert and work with other 2g parts.
2G turbo and non-turbo are vastly different. The 420a engine and trans are reversed from where the 4G63 engine and trans are mounted, so no, those parts will not work.
I very well know the 420a and 4g63 are very different. His profile lists a gst, so I thought I'd be safe to assume he was swapping a turbo model. I should have specified.
