awd stuck, rear end not spinning
maddadgsx
50
Feb 1, 2013
Fulton, Missouri
Took my kids to the creek for some fun this weekend and car sunk where I parked it. Had to get pulld out by a passerby. I noticed my rear tires would not spin. I got home and startd replacing my axle due to a clunking noise in front and found the last .5 in of my int shaft was stripped. Could this be throwing my LSD off???
Just barely fixed this same problem. It was the t case. I replaced it with another one. Just be sure you get exactly the one you need. If its a auto and 97 make sure it comes from a auto 97-99. 95-96 wont work.
Just take the bolts out and drop the t case and check out the splines and see if the output shaft spins when you spin the input shaft, maybe even hold the output shaft to give it some resistance and see what happens
