beekbuttons
- 59
- 0
- Jan 18, 2003
King of Prussia,
Pennsylvania
AWD car on 2WD dyno can be done in a few ways. Leon's is the easiest way, use a switchable transfer case. If you have a welded center diff or viscous coupler, you can just drop the transfer case and you're good to go, you're in FWD mode. If you don't have a welded diff or viscous coupler, you will need to install at least a welded viscous to convert the car to FWD use along with dropping the transfer case to put the car on the dyno.
Or you can just go to an AWD dyno.
Much easier, and less chance of tranny leakage from dis- and re-assembly.
