AWD driveshafts
Afroclipse
898
Dec 22, 2006
Houston, Texas
I really need an answer for this, can i use my a/t driveshaft on my m/t (i'm doing a conversion).
Its the Manual to Auto gear ratio in the rear end. Did you do any research before starting?
You run the Auto rear end with a Manual tranny and say goodbye to your T case.
The difference in gear ratio from the front to rear will cause your T case to try and compensate. It aint gonna happen.
I know about that he was talking about the driveshaft, dude its almost impossible to find a rear diff for my 95 gsx
Dude, you want 5 speed, you have to find a rear end.
Find a wrecked 95-99 GSX/TSI and pull the tranny, Tcase, and rear end. Not only that, youre going to need to change the axles in the front and possible the rear (if youre going LSD to non LSD or vise versa) Oh and the starter is different.
I already got the tranny and transfer case from www.Tigerjapanese.com. they even have non us spec skylines for less than 10 grand:sneaky: . I just need a 95 rear differential and thats it. oh and some axles.
