jtmcinder
DSM Wiseman
- 5,402
- 97
- Nov 4, 2003
Iowa City,
Iowa
Even 65% rear is enough to start snapping rear axles, assuming some power (such as what you'd get from a T28). Ask people who have the Cusco tarmac center.
AWD it's called power sliding.
I though its called gymkhana not drift for the AWD.
I've been running a Cusco Tarmac Gear 35:65 center differential with a FP Big28 turbo since 2008 and have never had any problems snapping rear axles. This is with big 275 width r-compounds in autox & time attack as well. I've never heard of said issue.Even 65% rear is enough to start snapping rear axles, assuming some power (such as what you'd get from a T28). Ask people who have the Cusco tarmac center.
WTFAnd that debacle ended with me pulling into the driveway and noticing that I had an empty trailer, no race car anywhere to be seen...
I do awd drifts every winter in my 4x4, it's like ice skating. To do it on dry pavement just takes a lot more power.
. It's definatelly a different technique to drift an AWD, countersteer when 1st getting it sideways, then mid corner when drifting you have to steer into the corner to keep the rear kicked out, and then toward the exit countersteer again vs. like a RWD it's countersteer all the time... But on asphalt same technique, just need more power, and speeds going into the corner are way faster than in a RWD, I don't have room at the next event to try and slide in AWD, so RWD mode it is, again.
I will post pictures on here after the event, I just have to put a clutch in it, and modify the power steering pump, so that way I still have the power assist past 5.5K rpms... It's kind of hard to transion when PS cuts outWhile it's true that the Audi 450cc-per-cylinder engines don't make anything close to the power of the Mitsu 500cc-per-cylinder engines, they are wonderfully reliable. As to the Quattro system ... while it was the best early on, both Scooby and Mitsu have long since surpassed it. Audi distracted itself making silly things like push-button ride-height control and has fallen way behind on AWD. They now are using Haldex-based systems like VW's 4Motion, Mercedes' 4Matic, and BMW's X-drive. Good for not getting stuck, but not what I'd call a performance AWD system.
