Awd clutch install Parts list
1gentalonfan
236
Aug 17, 2005
Orlando, Florida
im about to put a new clutch in my 1g and i want to make sure im not forgetting anything. I have a spec stage 3 clutch, fidanza flywheel, new clutch fork and pivot ball, the slave and master cylinders were just replaced before my clutch fork broke, oem tob and clip, and some amsoil to go in the tranny and transfer case. Am i missing something? I kinda feel like i am. thanks guys.
Use gl-4 only in the trans and gl-5 in trans case and rear end. I recommend red line mt-90 for the trans and it will take about 2.5 quarts.
Don't forget to tourque the flywheel bolts and clutch down to the right specs.
Might as well change the rear end lube whlie your at it. A new gasket for the down pipe to turbo o2 housing.
i actually just put on my 3" turbo back, and i just replaced the rear end fluid with ams severe gear(their gl-5) Thanks though i almost spaced that i even need to drop my dp. i might have to pick up a tubular o2 while im at it, im still running the stock.
