Resolved Avenger Gauge Cluster work in 2G?
eagle97talon
107
Nov 1, 2004
Chicago, Illinois
So today I was at a local junkyard and I found an Avenger with Speedhut white-faced guages. I removed the entire guage cluster from the car. My question is can I just swap this new cluster with the white guages for my stock cluster? What's the best/easiest way to do this? Thanks a lot
it should just be a direct drop in as long as the tachometers have the same rpm range. some non turbos had 8k rpms tachs and some had 9k rpm ones. hope that helps
Yeah thanks, I actually put in last night and it worked perfectly. Ill get some pics up some time today if anyone's interested
Solution
Glad it worked, I've had nothing both trouble with my speedhut gauges, but I won't get into the specifics since vendor feedback is not allowed in threads.
FYI - It is gauges not guages. :)
