auto trans slip?
Dave1288
May 23, 2006
North Granby, Connecticut
I have a 95 auto gst and when i get on the gas it down shifts and as soon as the turbo catches boost theres a vidration on the front passanger side of the car any ideas? :confused:
Sure its the trans?..if so go simple and cheap b4 anything eles....change the fluid and filter....also id personally take off the tranney cooler and clean it out also to avoid any clogs...
hope it helps
Jesse
thanks im sure it lets go at about 3000 rpm and it seams to b right when it picks up boost
Hey man, I have a 97 auto gsx and I've had the worst of worst trans problems. If your trans has any faults still after you change the fluid and filter like advised by the guy that responded already, give someone a call. I just sent mine out to a place called IPT in New Jersey, great group of guys, customer service is fabulous and they know everything there is to know about the auto trans. They are building mine hopefully now that I found them, it will never have to be fixed again, but they have guys running anywhere between 9's-12's on this trans. So if you have no luck look them up online and give them a call. Good luck with everything.
