auto to manual swap and now blinkers dont work
Bastard1g
363
Nov 15, 2003
Jacksonville, Florida
Anyone swap from auto to manual and their blinkers not work now? What is the check list on this?
Just make sure that the turn signal relay got plugged back in (it's located next to the ECU, kinda' under the radio... If you swapped out the ECU and/or removed the TCU, you might have accidentally unplugged it... Look for a single white plug with 2 rows of pins.. It's right in there, next to the OE fuel pump relay).
If it's plugged in, just verrify that it is getting a 12v+ ignition feed in to it.
:talon:
Awesome, thats what I was looking for. I allready have all the relays out in the open because my fuel pump and ecu wouldnt turn on witht he key on so I had to jump off the relays temperarly till I have time to find the problem. I just need to know if the ecu and fuel pump relays open on ground or power?
First, have you gone through and checked all of the fuses yet? -I would look into either the 40 Amp Battery fuse in the large fuse block next to the OE intake location, or the 20 Amp MPI fuse that it on the positive battery terminal. -If all of those check out ok, then start checkin out the relay coil paths..
Did you disconnect the grounds on the passenger's side of the center console, below the ECU's single mounting bolt on that side? -Check that as well.
Are you describing the locations for 1g's or 2g's? I didnt know that there is a fuse located near the positive terminal. Also, I am going to check the turn signal relay tommorow. I have checked most of the fuses and they all look ok.
Opps, my bad... I somehow thought that you had a 1G. Stratch the locations, but from a wiring aspect, they should be quite similar. If I recall, the 2Gs had a whole relay bank that was also right under the radio.
yea, I still need to look for the blinker relay. I saw a small relay over by the ecu and stuff, it is black and has a white plug. I will check that out.
