AT shift points with Upgrades
Salad 419
Jul 19, 2003
Hey, I have a remedial question that I couldn't find. I just got an automatic AWD for the wife and since she'll probably keep the car in DRIVE while she races I was wondering about the automatic shift points. Currently with the stock 5-speed mods (cams,turbo, injectors, ECU) the car shifts at 6250 RPM. Is the TCU pre-set for that shift point, or is the shift point determined from data gathered? For example, If I upgrade to a converter, ported head, 272's, 50-trim and all the supporting mods, will the car STILL shift at 6250 or will it shift higher according to engine dynamics?
Thanks,
Salad 419
The TCU is pre-programmed to shift at points that will not move. My car in from first to second shifts at 6900 and from 2-3 at 6500. The only way to shift higher (which there really isn't a point to shift past 6500 unless you've got some work done) is to manually throw it into gear with the shifter or to get an electromatic controller, like IPT sells.
Mike
