ARP studs
philipkrotch
Banned Member
904
Feb 9, 2004
butler, Pennsylvania
i had ARP head studs in my old motor and i put a new block in with the same head and an OEM head gasket. i think im going to put the ARP's in the motor i have in the car now when i drive it home this weekend, i was wondering if i am supposed to put the moly lube on it again and what i should torque them down too. thanks
You should always lube critical bolts and studs to achieve the most accurate torque readings. The specs would be the same as originally since they are not torque to yeild studs.
Rick - '91 GSX :dsm:
If you have moly lube, just install them like they were brand new.
If you use motor oil, I believe that the recommended torque is 110ft/lbs .
