ARP Headstuds
Well, yes you can run more boost without risking a head gasket failure, because they allow you to torque the head down more than the stock bolts allow(stock headbolts stretch). Also, you can pull your head off multiple times without replacement.
the arp's will lessen the likely hood of you popping a HG at higher boost, but its not like cuz u put ARP's on you can turn up the boost 3psi or something.
