Styxyr
- 273
- 0
- Apr 1, 2012
Searcy,
Arkansas
Happy easter! Lol what's a good brand for headers? Nothing ebay....
Bit of a long shot here but I am currently in Arkansas and my friends output shaft just bit the dust. Fairly sure the splines shredded in the transfer case. I have sourced a new one in Clarksville TN but I'm likely going to be needing a transfer case as well as I can assume the teeth in the transfer case input are shot to shit. Does anyone here happen to have a 2g automatic awd transmission and/or a 91-96 Transfer case in good condition they can let go of cheap? Been up for 24 hours after working land all day yesterday, covered in gear oil and at, minimal tools, and basically stuck here until I find the parts we need.
Any help would be appreciated.
The stock ported one works great, but id get a FP if anything.
Anyone have a complete 6 bolt block for sale? Needs to be running condition to swap with my 7 bolt.
. Also switching to a different o2 housing for an external wastegate for when I upgrade my turbo. Slowly going up xDCurious cause mine is cracked so good time to upgrade. Also switching to a different o2 housing for an external wastegate for when I upgrade my turbo. Slowly going up xD
Dang, was this with the ARP studs? What boost where you running?
Today I decided to go visit the family and just had to leave a mark when leaving sideswiped my moms Denali put a dent in my door and took my passanger mirror off barley scratched the truck
. I did pretty good with the stock 2g ported and an e316g internally gated.
What turbo are you going with? I was running 29+psi on the 16g with the internal gate. With little boost creep and held like a rock. This was with a 3" o2 housing and 3" downpipe. Fun little setup that was. I'd always recommend going external off the manifold rather than turbo.
Anything above 27 psi starts to get out of the efficiency range of the turbo. Doesn't mean it won't make more power after that tho.
Anyone got a 6bolt long block?
Anyone selling a Evo? #### this car...
super clear..
