Arkansas members
From what I was reading idle should be .67v which is where it is, and for a bad o2 since I have a wideband I'm gonna install should I just put it into the rear o2 spot and lock the rear voltage or weld a new bung on
Would moving the upstream to the o2 housing be a bad idea? I know it'll burn a wideband up really quick
To put it the front o2 spot don't you have to wire the front o2 into the wideband? Therefore eliminating the need of an extra bung for a wideband
My wideband had an o2 with it. Just pull the stock one out and replace with your wideband one. I think you can wire your wideband into the ecu wires to use the regular one. I've never done it before so don't get me lying.
Stand alone widebands have their own sensors I believe.
No.
Link has an option to -simulate- a narrowband signal and thus all it does is provide a switching signal for the ECU to read off of. You tune around that. If you replace your front 02 with your wideband, you'll be using a Simulated 02 signal activated via link. It is -very- iffy and very rarely works properly for an extended amount of time.
v3narrowbandsim [ECMTuning - wiki]
In other words you don't recommend it. I've heard of people using a wideband wired to link and to the ecu as in both sensors but idk if that's a good idea or not
It's the same thing. It becomes a simulated reading.
Some people have success with it. Some don't. I personally just.prefer to have a legitimate 02 sensor in place.
I also find that the rear 02 bung works great for a wideband sensor location
Just remove the rear 02, install your wideband, and disable the CEL for the rear 02 check via link.
I already have to cut off my front o2 bung and get a new one welded on or just get a new one welded on abd leave the old one in. Mine is seized inside of the bung
Well, Just paid for a nice little 1g eprom, should be here sometime the end of this week... lets see what else can i throw at this thing.
Nice. I got a couple of cheap 12s with 800w. It's alright, didn't pay for it so it's perfect LOL. Also pulled 2 alpine X model 5" speakers, x model tweeters and two brand new crossovers out of a truck. Fo free :)
Considering the kit costs 360$ new yeah LOL.
150$ and they be yours :)
[ame]http://www.amazon.com/gp/aw/d/B0013UVKX2[/ame]
