Arkansas members
For?
Also - Anyone. I need a 6 or 7 bolt bottom end. Don't care at this point.
Thats the 6 bolt I was trying to get. And as far as parting it to an extent I am but not getting rid of it just yet. Just ask me what you want
For?
The six bolt I got; I reused the oil filter housing not paying attention to the fact it didn't have a oil pressure sending unit. ( it also uses AN fittings to connect to the oil cooler. It also has a smaller oil filter.) Really don't know what year it is. I might try to pump tge oil up throught one if those fittings to get oil and just buy a aftermarket oil pressure gauge at a later date.
Getting so close now. Its just finding where all wiring hookups go.
Do you need the sending unit or the complete oil cooler?
Neither. I have both BUT the oil filter housing I got with this motor does not even have a hole for it. See the picture above how it goes from the oil filter and y's off to the sensor unit? Mine doesn't even y off. Its f ing weird!
I will just swap it out with my other one. I shouldn't gave to take anything off of tge motor to take sway the filter housings. However I will be keeping those AN fittings
Me too, wanna part the the tranny greanbean? Not really sure what you're looking at selling.
Stay away from that block of his. ;) I direly need that.
Sounds like they had an aftermarket gauge installed already. If there is an Allen head bolt anywhere in that housing, you can unscrew it and insert an oil pressure gauge there. That or buy you a digital one.
I'm looking for some 1g awd parts if anyone has any for sale or can help me find them. I live in Hot Springs.
I need a stock down pipe for a MT or a aftermarket that will bolt to the cat.
A MT 23 spline transfer case that has been inspected or can be inspected for any damage.
A 23 spline output shaft in good condition. Mine is knife edged.
And a early gear set style reverse gear that isn't chewed up.
I am also looking for a few interior parts like rear carpet and some trim pieces from a grey interior.
Any help would be appreciated.
Hmm. I just happen to have a 1gb body with a few odds and ends. I also have a 23 slipne output shaft (I swapped my 22 spline to bolt to my transfer case.) And a transmission but the syncros are gone..., I doubt I have any grey interior though. I am looking for a drivers side corner light. Got one?
And I have your transfer case pulled from a running and driving 1G. ;)
I picked up that light for you.
I don't have the light but I would be interested in the output shaft. Do you have any good picture of the splines? Where are you located and how much do you want for it?
Do you have any pics? I thought the one I had was fine and if spun freely but then I opened it and the bearing toward the tailshaft had come apart. If all the splines look good on the outside would you be willing to open it or guarantee it? If so where are you located and how much do you want for it?
I'm located in Paragould, as my profile says. :)
I don't exactly find it exciting to tear apart a transfer case. My reputation and feedback will speak enough for itself. I'm not exactly one to sell broken items.
I live in pangburn (pretty much searcy ). Shoot me a text at 501 827 five nine six nine. And il get you pics after work. It cam out of a car that had less than 90k on it......
What budget you working with? I could do 30-35$ shipped.
25$ pickup. But with gas nowadays.
Haha this has turned into Arkansas dsm swap meet :) I wont be needing a block till next year or mid summer though. When I decide to build something up.
You can have my current one. :thumb:
A bone stock 95 7 bolt. Thing is - I can't rebuild this block right now as I'm daily-ing the Talon. So, I need a block. The idea of performing a 6 bolt swap just sounds too common as I've done that a few times now so... I think I'd rather give a revised 7 bolt a shot this time around. :)
By the way, I have no server at work so if you sent me those pictures I haven't seen them yet.
