JamesH3
- 173
- 0
- Mar 14, 2011
Newport,
Arkansas
I'll sell you my bike for quite a bit cheaper
Holidays and funerals, man. Today is my first day back to work in over a week.
Agreed, same thing around here. Way too much family around I have been dieing to get back to the office. Luckily we are getting better weather this week and I can get the talon back on its own weight an driving around. Been installing my LC1 an it has been a bi*** because of the PO welding the exhaust into a single piece.
A 2.3 will see load differently than a 2.0. Sure, people have ran them untuned or without any sort of compensation, but why would you? If you're going to build a stroker, do it all the way. BSE, Stroker Kit, ARP Rod bolts, ARP Head Studs, a nice set of 272's, and a tuning solution. Budget, anyway. Otherwise I'd preach about head work first.
Meh, guess il have to choose between a bike and a build, what she don't know is the build will cost more. Question, I plan on going 2.3 stroke, will I need a tuning solution for it right off the bat? Like it not getting enough fuel or air due to the computer thinking its a 2.0? I plan on running a 14b at 12 or 14.
Of course no BS, and will get luke to do the oil port mod..
Priced stroker kits 1500$.... That's just forged bottom end. Not to mention the block work. If the motor is shot, il use green beans block.
. Thats why I went ahead and pulled the engine from my gst and built it instead of worring about all the other small stuff needed for that block. Plus you'll need the hardware for the block anyways. Brandons engine may or may not be shot but I would buy a block from tuners before using the block of death from beans.... In my opinion. I could be wrong tho
Well it is official. I am now a resdent of MOWMOW(Maumelle)
but my Talon is still in Searcy and my engine is in Little Rock. All I have left on the engine is to remove the bolt that is snapped of in the intake, bolt on the turbo, and a ss oil feed line for the turbo. I did however run into a small snag on the exhaust of the Talon. Since I went FWD from AWD and planned on using the the AWD exhaust my down pipe is a little to short to reach the AWD exh. Small potatoes compared to everything else I have overcomeNothing wrong with .040 over. I did that and have zero issues. You could do .060 over and most likely never have issues.
.40 require a 4g64 head?
Negative, besides a 4g64 head is sohc, wouldn't even consider it. Go with 2g 4g63 head. I believe 40 over would put the bore to 86( I'm memory serves me correct stock bore is 85.5) no reason the stock head would be a problem.
So I finally got the car back together and I fear I may have lifted the head from a boost spike last time I drove it...
I'm hoping its just from sitting and being cold but this was after an idle for about 20 mins.
Smoking - YouTube
.I'm currently looking for a bigger Turbo, and waiting on Bobby to get a front bumper so I can plastidip the car. Been debating on switching to a t3 setup, just wanted to keep everything "bolt-on".
It was about 45 degrees out and was putting out some good clouds. I'm not losing any coolant that I can tell and the oil looks fine as well. I'm gonna keep an eye in it and drive it around some this afternoon to see if it is just residue or oil that has built up from sitting. I've done the head gaskets many times before so its not a big deal just a pain to have to retune the whole thing again.
I already have a spare HG from my gasket set and will throw in some ARP bolts as well but want to make for sure before I do that. I I need a rebuild I'm pulling the whole engine to make it easier and clean up the bay and block. The wife sure doesn't want to hear this.
the pizza boy at the little Cesar's said so himself!! And crererazzzggyy bred and maybe a 2 leetirr MOWMAWntaindoo. Haha!
