General APSX narrowband sim min/max limits
THE REAL DEAL
462
Jul 12, 2005
Evansville, Indiana
I'm using an APSX D2 Wideband and replaced my stock front o2 with the wideband sensor so I'm using the simulated narrowband output to my ECU. APSX is really vague with their instructions so I need to make sure I'm doing this right. You can set the narrowband lower limit and the max limit on the gauge itself so I assume you have to set the limit from 0-1v which using their chart, my lower should be 9.0 and the max should be 11.0?
I don't have a way to log to see if it's cycling correctly right now because Evoscan won't connect to my car (I think my voltage is too low) and it's running around 12.5 at idle so I'm trying to figure out if I don't have it set up correctly.
Still curious if I set this up correctly but I think I found the issue with the 12.5:1 AFR. I pulled the pump and it's a 255 and running without an AFPR. I figured this was the case after fixing all my boost leaks and still running rich.
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
