JackH
- 0
- Sep 9, 2004
Pittsburgh,
Pennsylvania
A young girl T-boned my 91 Eclipse AWD Turbo.
Insurance company likely will total it and I have found a possible replacement. You people are way over my head with some of the things you are talking about but if you have time for a stupid question I have one. I do most of my own engine maintenance replaced my turbo, exhaust manifold, timing belt (and everything else in that 2 inch space. water pump, tensioner, idler, oil seals) valve seals (on engine, head not removed) so Im not a complete idiot. This possible replacement car has a bunch of mods listed below. What Im looking for is a car that is good reliable transportation like my old one and not something that I have to tinker with all the time scratching my head. Does all the stuff below look well matched and pretty straight forward or am I going back to my Saab 99 days of spending an hour under the hood every day before going to work.
Not looking for a guarantee but an opinion if this stuff is well matched and straight forward. Appreciate an opinion. Looking forward to surfing here and learning about this stuff. Also if I can keep the original car as a parts car are some of the parts interchangeable between the 91 and 93 ?
Looking forward surfing on this site to learn more about it. Thanks a lot.
1993 Eclipse GSX: All Wheel Drive A/C
Intake: Open Cone Air Filter 2nd Gen Air Sensor Custom 3" Air Intake Pipe Spearco 2-120 Front Mount Intercooler Custom Intercooler Piping
Exhaust: Ported 95 GSX Exhaust Manifold 2.5" tubular O2 Housing with external dump tube 3" Mandrel Bend Downpipe 3" Catco Catalytic Converter 3" Dave Barry Catback (Pressbent Meineke) 3" Magnaflow Muffler
Turbo: Ported Mitsubishi TD05H Big 16G Dual Stage Boost Controller w/ cockpit switch
Fuel Supply: 3000GT VR-4 Fuel Pump w/ Rewire Kit 550cc/min RX-7 Fuel Injectors Apex'i Super AFC
Suspension: 235/40/17 AVS Intermediate Tires 17" Speedy Atix Wheel KYB AGX Adjustable Shocks and Struts Progress Springs w/ 1.5" Drop
Transmission: Alto End Clutch Translab Shift Kit
Nitrous System: 25 shot wet nitrous Includes IHRA 30ksi pressure vent tube
Custom Water Injection Setup Controlled by boost switch
Gauges/Controls: Autometer Transmission Temp Gauge Autometer Boost Gauge EGT Gauge Digital A/F Ratio Gauge Dual Gauge Pod Pillar Indicator Light for Water Injection operation Indicator Light for Nitrous Operation Cleanly mounted nitrous/boost switches
Insurance company likely will total it and I have found a possible replacement. You people are way over my head with some of the things you are talking about but if you have time for a stupid question I have one. I do most of my own engine maintenance replaced my turbo, exhaust manifold, timing belt (and everything else in that 2 inch space. water pump, tensioner, idler, oil seals) valve seals (on engine, head not removed) so Im not a complete idiot. This possible replacement car has a bunch of mods listed below. What Im looking for is a car that is good reliable transportation like my old one and not something that I have to tinker with all the time scratching my head. Does all the stuff below look well matched and pretty straight forward or am I going back to my Saab 99 days of spending an hour under the hood every day before going to work.Not looking for a guarantee but an opinion if this stuff is well matched and straight forward. Appreciate an opinion. Looking forward to surfing here and learning about this stuff. Also if I can keep the original car as a parts car are some of the parts interchangeable between the 91 and 93 ?
