apexi neo install?
stomp
117
Jul 17, 2007
Vernonia, Oregon
Just wondering if they gave the right directions as to hook up the the throttle position wire right,on there instructions they tell you to splice into pin 87 on the ecu that would be the (closed throttle position switch)but,pin 84 is the actual (throttle position sensor) ,shouldn't pin 84 be the right one to splice?
I followed the pinout in the NEO manual to a T and my install went smooth and everything works fine.
i installed mine and the throttle is like a switch. either 0% or 100% throttle. its like a switch. did i connect the wrong wire? also i cant mess with karman like you can when you select like flap. it gives you options, but on karman it doesnt. any thoughts? thanks
slowboyracing.com
