A'PEXi BNR32 (300lph) intank FUEL pump ? anyone install on a dsm
djsm1769
32
Mar 12, 2004
connecticut, Connecticut
has anyone installed this pump on a dsm??????????
this only info i found about it.
http://www.stealth316.com/2-fuelpumpguide.htm
>A'PEXi part number 404-A011<
goal- intank 675-750hp pump
difference:
300lph apexi BNR32 .VS. 277lph supra pump.
anyone install this or know anyone that has this pump??? couple day gonna order this pump cause it out flows supra pump. gonna stay intank cause I cant sump stock cause car to low or have fuel cell in trunk cause of stereo.
Why would you run this pump instead of the Supra pump?
From the flow data they're very similar, with the Supra pump being half the price and a direct swap in place of the stocker.
Here's some more flow info on the Supra pump
From these tests the Supra pump at 14V flows 240lph @ 73psi. Assuming you run a stock base fuel pressure of 38psi, this translates to 35psi of boost.
By the way that is a very good article. It sold me on the VR-4 pump when I was fuel pump shopping.
Those are some big numbers your shooting for. Pushing a single pump to its limit and taking the risk of running out of fuel isn't worth it in my opinion.
My suggestion is to run the Supra pump in-tank and either a Bosch or Walbro inline pump OR run two Supra/Walbro pumps in-tank.
But what the hell do I know?
By the way you live pretty close to me, maybe I can convince you to give me a ride in that beast once its done.
