anyone with after market steering wheels, is this the right hub?
Chuckt
681
Oct 17, 2002
is the momo hub i need model 6001? if not, what is the hub number i need for a after market steering wheel? thanks
ok, 6101 is the right momo hub. Are there any other hubs that fit our cars?
Defiant said:
Grant uses an odd 5-screw scheme, while most manufacturers use 6.
i couldve swore that someone on here said they used one on their car, but i dont know what wheel they had either, so that could be a reason why they were able to use a grant.
well now i know that wont work, aight chuckt scratch that idea
im going to use the momo hub cause i know it will fit and i dont want to do the same thing 2 times and end up spending more money than i had to originally just to save a few bucks. Mike, your wheel has 5 bolts and the one i ordered has 6 so that wont work, thanks tho
TSiAWD666 said:
Do any of the hubs mentioned in the thread change the steering wheel position?
Some may be different depths. However, most are a crush design, so you could clamp it up and make the wheel a bit closer to the dash. Also, different wheels have different "dish" to them.
My Pilot wheel came with a metal piece attached that with 3 bolts mounts to my grant hub, the grant hub doesnt make contact with the wheel theres a piece in between them. Thats what the 5 screws go into, didnt your new wheel come with a similar piece?
i dont have my wheel here yet, its just ordered. Ill wait to order the hub till i can see the kind of fittment it has. on the cruise control thing, i dont use it hardly ever so its not a big deal.
i someone has verified that 6101 is the right hub, but thanks for the input anyways. Was it difficult taking out the airbag/steering wheel to replace? anything i should look for, stay away from?
