Anyone running MegaSquirt
DSMTurbo2
33
Dec 17, 2002
Traverse CIty, Michigan
Is anyone running megasquirt 2 v3.0 board with MS2extra 2.0 release?
I am really close to having this sucker good to go. I am confident that my wiring harness is all good, I just have not been to sure on the ECU settings because all the tutorials I have been finding for the 4G are for different versions of MS or MSextra.
Does anyone have a .MSQ file for 4g63 that I can use to compare with?
This has been an amazing project and has been quite taxing, but I am ready for the rewards.
PS I did find this if anyone has some MSQ's they would like to share. this
Thanks and cheers
Erik
i did a write up on it. i just installed it about 3 weeks a go. i just passed 900 miles on it so far.
i dont know the difference between the ms-2 megatune. compared to the MS-1 settings.
i have a ms-1 3.0 MSNS-E 029y5. 4 bar mapdaddy with Baro and fan mod. i have a
1995 100% stock Eagle Talon AWD. i am also using Stock 1995 cam and crank sensors.
i followed this for settings.
http://tinyurl.com/4ugh24
http://www.dsmtuners.com/forums/tuning-engine-management/309447-megasquirt-install-progress.html
i will e mail you my MSQ just PM me your email address.
you can find one of my MSQ's here
MSx/Extra EFI • View topic - detonation problem or preignition "Progress made"
I still have a long way to go on tuning. but it is running like a champ. i just have to work on fine tuning.
I am running MS2 and just want to say I love it! I like having a 16X16 VE fuel map
Just for warn, the MS2 and MS1 are completely different mods!!!! this is for anyone wanting to start out.
For DSMs I recommend using MS2extra if you are doing the MS2 version. all the 4/2 cas are calculated out.
I am on learning how to tune it right now and got the WB hooked up and everything. I am finding out tuning is kind of tricky but it runs really REALLY nice once it is dialed in.
Something I just looked into is Tuners Studio for MS. It is a lot nicer to tune with then Megatune.
I am looking with someone with another Spark map for my car, the one that I have works ok but I think it is too agressive.
Once I find it I can give you msq to start with. But VE tables are different for every car.
good info.
anyone know why my RPM would be repeating this during cranking.
shouldn't I be getting a solid signal? it just keeps doing this over and over.
Looks like you are not getting a signal from your 2nd trigger
I posted why in the other thread
