Anyone running Defi Link gauges?? Look inside pls!
what do you mean by where the gauges are wired? I have Defi Links in a 2Gb. I have 4 gauges: EGT, Boost/Vac, Oil press, Water temp. I have the controller in the center pod under the stereo head unit. I tapped illumination from the stereo harness as well as switched power and constant power. Ground is grounded to the center console frame. I also ran the switched power through a mini toggle switch and placed through a hole on the console, that way if I need to have the key on, I don't have to listen to the low oil pressure warning. I put the EGT and Boost/Vac in the top 2 holes of a triple gauge A pillar and the Oil pressure and Water temp are on corners of the instrument cluster in an Autometer mount.
  • Wanted 6 bolt NT water pipe
    • chrisman287
