420A Anyone running a BEGI FMU?
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
I'm running a BEGI 2025 rising rate fmu on my turbo 420a, removed stock fpr, with 440cc injectors. Is anyone else running this fmu? I have my base fuel pressure at around 20psi, however even with the brass adjustment needle turned all the way out(supposedly lowers maximum fuel pressure/rate of increase) the fuel pressure still skyrockets up to 90-100psi. Which is WAY too rich, reading under 10AFR. I've heard of a restrictor I can install in the signal line to possibly slow down the rate of increase, but not sure where to get one.
I have used a Begi fmu in the past and works great, you have to keep the original fpr installed, fmu will not control the standard pressure without the stock fpr.
