Anyone knows specs?
1991TSiGFORCE
52
Nov 11, 2007
Brooklyn Park, Minnesota
I'm putting my car back together and I'm having trouble finding specs for my car parts. I drive a 91 Eagle Talon Tsi AWD turbo. If anyone knows please let me know. I'm looking for the whole bottom end specs and also torque specs for ARP head studs. Thanks.
Hope this helps.
Intake manifold bolts 132 to 168 in/lbs
Cylinder head bolts 65 to 72 ft./lbs
ARP Cylinder head stud nuts are 80ft-lbs with moly lubs
ARP Cylinder head stud nuts are 120 ft-lbs with motor oil
Front Case bolts - 14 to 16 ft./lbs
O2 to downpipe bolts/nuts 43 ft./lbs
Oil pump driven gear bolt - 25 to 29 ft./lbs
Oil pump sprocket nut - 36 to 43 ft./lbs
Oil jet bolt - 22 to 25 ft./lbs
Connecting rod cap nuts 36 ft./lbs.
Pressure plate torque = 11-16 ft-lbs
Flywheel tourque = 94-101 ft-lbs
  • Wanted 6 bolt NT water pipe
    • chrisman287
