anyone know who checks obd1
Freeze
102
Apr 25, 2008
Louisville, Ohio
i am throwing a cel. it used to just come and go when i got into boost but now its on all the time and i think it might be an 02 sensor but i went to autozone and they said they only check obd2. Any suggestions on what i might be able to do or where to go. Thanks in advance
You.
(After a quick trip to radioshack or home depot).
I used a 12v audible buzzer for mine (find it easier than watching the mulitmeter).
Total cost of wire, buzzer and alligator clips = under 10$.
Walktrhu:
ECU Code Checking
You.
Walktrhu:
ECU Code Checking
Yeah:thumb:
Thats all there is to it, very simple procedure
If you can't perform this procedure at least, the 1g dsm may not be the car for you:rolleyes:
Eventually when you get a logger, which should probably be the first thing you buy, it will read the codes out for you!
Pick up a used compatible palm from ebay for $20-40. You could buy a cable for $25 or make one for cheaper. Then download MMCD and you're all set to log rpm,knock,timing,etc
http://mmcdlogger.sourceforge.net/
yes i know i need a logger but i have been inbetween jobs and everything and some other things have been going on but yeah i am heading over to ebay right now to get everything i need thanks guys and i will be getting this solved
sorry to ask this but i am still kinda new to the whole dsm scene but is there anywhere i can get a cable for a palm like in the link above?? i just purchased a palm from ebay and it should be here within the next week i need to find out how to make a cable or buy one thanks again in advance
