Anyone Experience Fuel Pressure Drop From Low Fuel Rail Volume At WOT?
Car Cannibal
691
168
Jun 7, 2003
Chicago, Illinois
I've seen logs of this happening on other Platforms when the cars Injectors and Fuel needs get to be too much for say a 5/8th ID rail, the pressure starts to drop and IDC rapidly climbs.
I'm pretty sure my 4psi off at 31psi of boost is due to a rail volume issue on my 850cc Injectors now. I don't know what the rail ID is on my FIC but I'm curious if others have seen or experienced this?
FWIW, my fuel system is
DW Pump
Modded 1G Hanger with 3/8th hose (no hood with O-rings) and -8an outlet
-8 Fuel Line
Magnafuel -8 Stainless Filter
FIC Rail with -8's
FIC 850's
Aeromotive Reg with crazy 180 degree bend on the feed line in:hmm:
I'm more inclined to think your issue Is probably a voltage drop at wot. Your fuel system is Definitely sufficient to support 850cc injectors. Do you know what your voltage is when your showing this pressure drop? That or a failing pump, leaking feed line at the pump, or clogged filter.
Also have you tested the regulator to see if it is actually functioning properly?
  • For sale 2g 2GB Eclipse Reverse Lights ( with bulb sockets )
    2GB Eclipse Reverse Lights ( with bulb sockets ) $35 + shipping & paypal feesYou must be...
  • For sale 2g Tan Sun Visor Set ( with home button & hardware )
    2G Tan Sun Visor Set $50 + shipping & paypal fees* home button * hardware includedYou must...
  • For sale 2g 2G Black Ashtray/Cup Holder
    2G Black Ashtray/Cup Holder $35 + shipping & paypal fees* both sides open and close as they...
  • For sale 2g 2G OEM Radio Brackets
    2G OEM Radio Brackets $35 + shipping & paypal feesYou must be registered to see element.
  • For sale 420A 420a Miscellaneous Parts
    Hey Guys I have a 420a car that just came in, if you’re looking for any miscellaneous engine bay...
