Any suggestions at all please.
mrxchan
Jun 9, 2006
Worcester, Massachusetts
I have a 95 Gs-t, and Im afraid of running into all the eclipse engine problems because it has like about 135k on it. I really want to keep it and swap a new engine into it. Does anyone know any websites or places where I can get like the best long lasting and strong engine. I just want a good engine so I wont run into those huge problems. Any suggestions please? Thank you
Im guessing you are talking about crank walk, its not as huge as everyone makes it out to be. Here is a link to a cheap way to fix it>>>http://www.angelfire.com/pa4/crankwalk/, if it hasnt happened yet the likly hood of it happening is slim. I would take it to a local DSM shop, and have them check out the engine, and see if its suffering from CW. Also any engine with a piston can CW, a 1G 6-bolt are the prefered engines to swap into 2Gs to make sure this doesn't happen, just google "4G63 engine for sale" you should get some hits from that.
Dustin
If you have made it to 135k without crank walk then I wouldn't worry about it. But Ebay for one example usually has used 6 bolt engines for sale and like was said before they are less likely to have a problem.
