Any harm running higher voltage alternator?
mosul210
295
7
Aug 7, 2003
Hill Country, Texas
Hey folks I noticed my car will be hard to start sometimes, recently replaced battery with new unit.
I tested the voltage on the battery at idle and it reads a steady 14V, with the head lights on it drops to about 13V and with the headlights and A/C on it drops even further to approx. 11.5V.
I am suspecting a bad alternator perhaps? Its an aftermarket unit rated at 75V. I found a remanufactured unit (direct replacement) rated at 100Volts, would this be a safe upgrade for my vehicle (1G AWD)? Any other modifications besides replacing the fusible link to 100Volts? And lastly any general harm that may occur as a result of the higher voltage unit? (BTW will also replace the belt at the same time).
I did the Saturn alternator swap and my car runs a lot better! I made a heat shield out of a 1g air can cover. I read one post about the alternator going out because of the exposed bearing in the back due to the high heat.
I bought my 100amp at advance auto for $100. You can find them at the J yards but I went threw 2 before just buying one with a WARRANTY!
http://www.dsmtuners.com/forums/articles-electrical-wiring/272646-saturn-alternator-swap.html
Check this out. I did this, and its not too hard to do, and much cheaper than going with the 100 amp unit. Output is 96 amps
Well I found a remanufactured 1G alternator rated at 100 AMPS so no modifications required as in the Saturn alternator - which is also a great unit from what I read.
Any mods besides upgrading the fusible link to 100 Amps?
Don't change your fusible link size.
Alts are rated in Amperage, not volts, there's a big difference.
People swap to the Saturn Alt because they are better built and don't have problems with the voltage regulator like the Mitsu ones.
After 3 Mitsu alts I've switched to a Saturn one.
Ok but should I change the stock 80AMP alternator fuse to a 100AMP fuse? The new alternator is rated at 100AMPS.
