Any Ebay 16g turbos worth buying?
Depends how much you love your engine.
Well if you have a built motor it would be idiotic to cheap out and take a chance that if the turbo would frag, sending metal pieces would be sucked into the engine. (or the nut in the end of the shaft comes off)
Well if you search there is a very interesting thread about a guy as he used one and kinda reviewed it. It was very informative and I don't think he had too many problems and it lasted quite a bit longer than everybody thought it would. If you can't find the thread I'll look for it later tonight.
You can only use an evo3 turbo, and you are better off getting a real 16g than buying the knockoff and later down the road regretting you wasted your money it when it fries.
There are about 3 years worth of Ebay turbo threads. The vast majority of those threads all came to the same conclusion this one's coming to.
