Any downside to 7-bolt 1Gs?
Vegas Smith
5,193
3,155
Dec 2, 2002
Houston, Texas
Hello folks, I have to a chance to a buy a 94 eclipse GSX in great condition, 151k miles. What would be the downside of the 1g 7-bolt? I imagine it would be harder to buy used parts for it. Does anyone a link or page that maps out the pros and cons? Thank you.
The bad rep, IMO, comes from inexperienced people doing one simple thing: Not wiring their clutch out.
True, the split thrust bearing is superior in handling lateral load wear, but ANY car that's modified will more than likely have a pressure plate with clamp forces upwards of 2900lbs. So of course crankwalk can happen on any car when you apply that much lateral load on an engine with zero oil pressure on start up.
I think crankwalk is way over rated and gave 7 bolts and unwarranted reputation.
I think the only thing is the rods in a 7 bolt arent' quite as strong as the 6 bolt. I may be wrong on that, i been out of DSMs for a while and i'm a bit foggy. That's not really an issue cause any time you're building a car rods/pistons are among the very first things to upgrade when you're rebuilding.
You are correct. As far as I recall the big end of the rod is slightly wider in the 6 bolt and the small end (wrist pin hole) is slightly smaller in the 6 bolt. 6 bolt rods are often used as a cheapo hi-po build option but the machining preparation of them for use on the 7-bolt crank has to be PERFECT or else...or else.
We ran 11.0 @ 126 on a stock 1G 7 bolt with 134k on it, then pulled it when we did a built 6 bolt and it's still running fine last I heard in a 2G.
Also, remember that all EVOs have "7 bolt rods" and plenty have made as much power as stock 6 bolt bottom ends, if not more.
  • Wanted 6 bolt NT water pipe
    • chrisman287
