Any body running turbo lab custome turbos
danieltovar
281
Apr 3, 2011
palo akto, California
Guys i habe an turbo made from turbo lab. So i would like to see if someone is runing something close to my turbo or same and what has been on performance.
My turbo is
compressor wheel 53 x 71mm 11 blade gt3071r, with 16g cover machine
turbine wheel 54 x 61mm 11 blade tdo6sl2
8cm turbine housing fully ported and polished, 37mm internal flapper
The mid is an tdo6 section oil cooled only
I have not found any logs or alot of reviews.
I am. TD05 20g... 40 lbs/min when I was internally gated @ 23 psi, now with EWG and waiting for a stiffer spring its about 39 since it only holds 22 psi, but I did run a best of 12.78@110 last weekend... Ill have a lot better things to show when more boost will hold
