antilag bog? can only build 5 pounds
quik4g63
51
4
Feb 27, 2009
Sarnia,
im having a problem using my dsmlink antilag feature with my T67....
i can only build 5 psi at the line and when i launch, i just bog until i spool again.
any way to build more boost on the line?
thanks.
I guess your talking about launch controls...what is your rpm set at? I have a 50 trim at 4500 build 2psi, then as soon as I drop the clutch shes gone and boost rises....quick.
it was the anti lag i was talking about i have my antilag set for
10 degrees ATDC and 0 enrichment.
i activate als at 5250 rpm
and my launch setting is at 5500
am i missing something here?
whats the two step compared to the antilag?
2 step is just a launch rev limiter so you don't need to feather the gas pedal so much.
Anti-lag combines the 2 step rev limiter with modified fuel and timing to put additional load on the engine while in neutral so its possible to build boost.
How long are you trying using anti-lag for? It wont shoot up to 20psi in 2 seconds.
If it's working corewctly, it will.
Within 2 seconds I could have 20 psi on my T4. 2 seconds later, both wastegates are wide open roaring flames. It does work that fast.
Post a log so we can see all of your settings.
  • Wanted 6 bolt NT water pipe
    • chrisman287
