Anti-theft Reset? please help
Did you put the key in the door to get the alarm to turn off?
i unhooked the battery because the driver side door isnt hooked up to it, the passenger side is and the trunk is corroded so i cant get the key in there.
you said in the other thread that you did insert the key in the drivers door to get it to turn off. Hook the door up and put the key in to reset the alarm and see if it will start.
i did in the passenger door and it didnt work
