another running lean at wot, with cylinder 4 misfire
joe sobo
846
Dec 30, 2007
stuart, Virginia
i have searched, but nothing really pionts to a cause. every post i see, they are running other than stock setup.
when i drive the car, it runs fine, then randomly loses alot of power, then check engine light came on. so i floored the gas, and my aem wideband shows that the car is running extremely rich(to where it just shows the dotted line).
i just bought the car with a busted timing belt, and had to get the head redone.
Sounds like you need to go back over your work. Check the t-belt, the CAS to make sure there on right, and figure out why the check engine light came on. I would also do a compression test to make sure the Head gasket sealed. It sounds like the motor felt some type of knock and it pulled timing.
the check engine light code is for cylinder 4 misfire
well, i thought to check the timing again, but because the problem comes and goes, i would think that it would be more electrical? yes, no?
plug wire? coil pack? clips on the injectors secure? Could you have an injector with a failing coil? There are alot of possibles with just a misfire # code.
Your aem wideband maxes out at 10:1 anything below and it wont show it, the funny part is that our cars are supposed to be run at around 9.?:1 at WOT.
right, but it is running lean , past 17:?1. at wot.
so, i let the car cool down for the last hour, and i just just let it warm up for like 2 minutes, and then blasted it down the road, and it ran,boosted, and richened up like it is suppose to. i have new wires, plugs. but i do not have those clips that hold the injector wires on.i checked them anyway, and they did not pop off
UPDATE
ok, so i put new plugs, new wires. i am still getting the cylinder 4 misfire. so i swapped my injectors around. i switched 3 and 4. this also did not help at all. it still says cylinder 4 misfire.
does anyone have any experience with this problem.?
well, the problem is that if i shut the car off, and start it right back up, it will be fine for a period of time
What is the EXACT code you are reading? It sounds like you may actually be getting a P030X code for Random Misfire because of your lightened flywheel perhaps.
You need to run br7es or bpr7es I would recommend br7es because of the not protruded tip giving you room for error (overboost). Bpr6e s plugs are to be never used after you upgrade you intake or exhaust and you have done both. I have personally experienced a problem running bp6es plugs with only an intake an hard piping. It missfired no matter how often I changed the plugs. Soon as I switched to 7's I had no more problems.
what is the exact code you are reading? It sounds like you may actually be getting a p030x code for random misfire because of your lightened flywheel perhaps.
i was getting code p0304
i have since put bre7 in, and now have no more misfire
    • Sdcryan1
