another fuel pump problem
honduraneclipse
226
Apr 13, 2003
revere, Massachusetts
1990 awd with rewired supra pump
on the connector side of the wiring ( towards mpi relay) the SOLID BLACK wire has 12v when the key is turned towards the ignition side.
Shouldn't it be the BLACK/WITH WHITE STRIPE wire that has 12v with ign on?
So of course the pump test connection does not work( it seems to spark when I jump a wire to the positive battery terminal) and I see no voltage coming out of pin 3(mpi relay) when ignition is turned on.
any help will be appreciated. thanks.
Yes the stock fuel pump connector black/white should get +12V with ignition on via the fuel pump relay pin 2 black/white (when relay is activated). Relay pin 3 (also black/white) should be +12V ignition switch. So the relay just connects pin 3 to pin 2. The black wire is supposed to connect to ground. Sounds like the wiring is messed up. Connecting +12V to the black wire should have been a complete short. This is all for the stock wiring. Maybe someone changed everything for the Supra pump?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
