1G Amazon Rad shroud? Anyone ever use one of these?
LostInColorado
33
28
Apr 22, 2024
PARKER, Colorado
I was browsing the web, looking for alternative ways to save space on my 1gb radiator cooling, and found these on the the Big-A website. Looks very decent.
I just wanted to get any of ya'll thoughts on it.
Ah, i see. I'm sure it's cheap, but was just thinking it might make a good base to work off of? Maybe later, add some more mount tabs(now that you brought that to my attention), and better quality fans.
The shroud is ok but the fans will not help. A set of 12" Spal fans, instead of those, would do a very good job, but each fan is $100+/-.
I run twin Spals, one pusher one puller since my Turbo and piping gets in the way of two pullers. Installing a small air dam under the radiator helped me a bunch. I robbed one from a 3rd gen Camaro/TA and cut it down to about half of its original height and welded a few nuts to the bottom of the radiator support to bolt it up with.
