altnatior any advice
known as sarlo
Dec 27, 2004
virginia beach, Virginia
ok i think my alt. went bad today, i am planing on swaping a new one on a 90 talon tsi fwd, i read some on the book and it said to check the relay fuse, how do you check it? also any other advice to make the swap easier would be nice so let me know. thanks ryan
pull the lower plastic cover out on the drivers side, u need to take it off to pull the big ass bolt out that holds it in. other than thats its easy. i just happened to change mine yesterday and it took less than a half hour. u should have no problem. :thumb:
yeah but there is a att.fuse relay, and the the att. fuse? i see the att. fuse, but the att. relay fuse has a black top so i can not tell if it is blow or not.
