1G Alternator Swap (Intrepid into 1g dsm) (SOLVED"DOES NOT WORK")
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
I’m looking for an alternator upgrade for my 90 talon. I’m just curious if anyone has tried putting an Intrepid alternator (99-01) or Chrysler 200M alternator into our cars?
The housings look similar in pictures, but I don’t have a physical part to test.
Thanks
I know you're asking about Chrysler alternators, but thought I'd mention the Saturn alternator swap was the go-to for a long time. They're cheaper and more powerful than the DSM units. The alternator from the 93-99 Saturn 1.9L DOHC motors is what you're looking for. Most involved part is some grinding and filing and a little rewiring.
Thanks for the responses both of you.
I am aware of the Saturn swap, and I definitely have the tools and experience to complete.
I guess I’m always just looking for more “Junkyard”
Upgrades to our cars that may not have been discovered yet.
I suppose I was more or less curious if this could be a viable option for those who just want a simpler install but still get a bit of an upgrade.
It’s a Mitsubishi alternator that should be rated for 130Amps. I was hoping this particular case had already been touched on and didn’t have to get one myself.
I used this alternator from a 1998-2002 Saturn . You barely have to grind the block .
Also I made a quick tensioner using the factory tensioner and a small peice of metal (its temporary but works) .
Could not find a new oem alternator so I got this from the wrecker for 30$ 14.3 volts at idle and when 13.5 heat soaked .
The bonus of this alternator is you dont have to worry about the stupid fan hitting your tensioner. Belt goes on the ribs closest to the fender nice an straight
Make sure you get the plug also.
And alls you have to do is remove the factory rad fan to get room to get in there with the grinder and the new alternator.
Its alot easier than removing the power steering pump.
I'll mention the alternator in this picture (my post) with sadly the same bracket, is still going strong. Figured I'd do an update, for curious minds.
It's outlasted (about) 3 alternators if my memory is correct. It's been a permanent temporary fix at this point LOL I wish I posted the wiring I did but I didn't. If any ones interested can send pictures LOL
It would be a nice addition to this thread to have the wiring explained also, if you had it. :thumb:
Sure would be, as I have read all the posts on the Saturn alternator mod and wiring and there is many conflicting posts on what is the proper way to wire it in the car. Most common issue seems to be where is the proper location for the S-Wire as this is the most important to have right, If memory serves me correctly
