2G Alternator ground location
Mexjzl
Apr 15, 2022
Santa Fe, New Mexico
I have a Mitsubishi eclipse gst 1998 just bought a new alternator the duralast gold but Im having problems locating the ground cable the Old alternator didn't have a ground connected to the alternator I do see a cable cut on my wiring system does anyone know If the cable is the ground cable or where is the ground cable located anyone
Alternators are usually grounded by the body in most cases. You can attach a ground from the case to engine block or chassis as an added ground. Think one of the broken wire is for the stock oil pressure gauge. Looks like you have 3 broken wires?
Look like I have 2 cables cut but I could add another ground to the chassis of the car or it goes back to the battery
It does not have to go to the battery. From the case of the alternator to engine block or chassis.
@Mexjzl are you having electrical issues? Here are a list of grounds in the engine bay
- Battery to firewall
- Back of intake manifold to firewall
- One of the starter bolts should have a ground to harness that runs under the thermostat housing
Would you happen to have the fsm pictures of the locations?
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
