marksae
- 123
- 1
- Jul 13, 2002
Bay Area,
California
Alright.. i've gone through some hell w/ my alternator belt on my 1g. Ever since I removed my AC belt, my alternator belt has flown off 3 times, and I've shredded 2 of them. If i leave it too loose, it flies off. If I tighten it too much, the belt shreds. I'll check my pulleys to make sure they're all lined up and aren't dinged up. Will overtightening this belt cause it to shred?
As this amalgamation of threads shows, the usual causes of alternator belt troubles are:
1. Failed harmonic balancer.
2. Bent pulleys.
3. Pulleys put on backward.
2. Bent pulleys.
well i just thought i would post about the alternator thing, it boogled my mind, tell me what ya think thanks,
so i put a lock washer in there and tightend that thing as tight as i could and the belt if tight, i think i was brekin belt because that back bolt was only finger tight and it finally was commin out then i drove it and the same ol same ol..im buying wires and plugs this weekend.. ill keep up updated on the changes
