Car Cannibal
- 691
- 167
- Jun 7, 2003
Chicago,
Illinois
Heat and fluids are the main killer here but....
I've rebuilt my alternators since I've owned my 1g and put on 160k miles, it's getting old. I know there's the Saturn update which isn't the easiest but that's a good option if you wanna do all that.
But for is keep it stock but make it better guys....
An adjustable, external voltage regulator might be all that's needed here. On the Grand Nationals a guy named Red Armstrong created a nice, small adjustable voltage regulator that wired into the alternator and allowed the user to set the voltage via a simple screw on the regulator. Mine was always set around 14.3v viewed in the car, probably 14.5v at battery.
Anything like this for the DSM?
My alternator rarely just died, it would charge on startup like normal, drive around like normal but eventually around 20k miles the idle charge, when the car was warm or at night, would drop really low, 12v etc. Once you started driving it would return to 13.5v etc volts.
If there's nothing available I'd have to think a regulator like the above would help most of us until the diodes or regulator dies much later than we regularly see.
Are the 1g and 2g alternator connector plugs the same?
