alarm system taken out
FunkMasterChipZ
200
May 25, 2004
rochester, New York
ok i found a 91 tsi :talon: talon and the guy says it wont start because the alarm system was taken out......or something along those lines i couldnt understand him too well.....has anyone heard about this before? i searched already and didnt find my answer... :(
If the previous alarm had a starter kill relay, it was probably removed without reconnecting the starter wire.Find it(in the steering column area) and reconnect it.
are u really sure? that sounds sorta easy......oh well i couldnt understand this guy he was like islamic or somethin and what do i reconnect it too...
When an alarm gets installed with the starter kill option, the starter wire is cut and a relay is put in.The relay will open the starter circuit when the alarm is armed.Chances are that is your problem, find the wire, it will be cut in half, and reconnect it.It will be a 12-14 gauge wire coming from the ignition cylinder.
