truwarrior
- 1,422
- 6
- Dec 19, 2002
My car is slow...missing like 50-75HP. I can feel air puffs IN and OUT from oil cap and valve cover hole to the intake... Is this normal?
When I boost leak the car I I can fill past 15psi but it slowly leaks out from where I don't no besides if I remove the oil cap I can hear air hissing and pressure build up in the valve cover. It takes about 20 secs or so for it to drop from 15psi to 0 psi.
150,160,150,150 compression
no smoke out the exhaust
PVC leaks very slightly but when blocked off the air still got into the valve cover area.
. Still leaks if attached to the throttle body elbow.
