Hole in valve cover?
ExpresS
280
May 12, 2009
Deptford, New Jersey
Looks perfectly drilled. I saw this while shaving my cover. Drain hole of some sort? :hmm:
What does it do my friend has his 2g with water or coolant coming out of it the other day, and he had some fluid between the exhaust manifold and the head bubbling, kinda like oil or a mixture. Any ideas.
Yeap, no worries that's how they all are :thumb:
That's weird that any type of coolant would be coming out of there.
Check the spark plug area, if it's coming out of that drain then it must also be in the spark plug area.
Take some pictures, that would probably be best for further help.
I wonder if you could run a small tap in there and put a nipple in it and run that off to a catch can. No mess then. Or find a nipple that would be a tight fit you could lock tight in. I never noticed anything coming out of mine.
Sorry snowboarder714 I reread the entire post and get it now...no more posts after an all night 12 hr work shift. Maybe the cover is cracked on the inside leaking oil into that sparkplug well drain. sorry again.
