air intake install
jw_55_55
108
Oct 3, 2005
Silver Lake, Wisconsin
Sorry for this being such a noob question but here it is. So i just bought a dejon tool intake pipe for my 1G gst and after taking off the old plastic air intake i noticed i had to remove more lines than i was going to be putting on the Dejon tool one. Any ideas what these lines are for??? One of them wasnt even hooked up(not worried about that one) but the second one seems like it is hookep up and i followed it to under where my battery is located. is this line important or not? thanks and sorry again
One is for the crank case breather, which you can have unplugged from the intake and just pointing to the ground or you can add a breather filter to it on the valve cover. I believe you can just leave them hanging or zip-tied somewhere they should be fine.
The one going under that battery is the charcoal canister this one just unplug. The one you said that was unhooked which is not good and since you where pulling in unmetered air. Just put a catch can on this one or something to catch the oil.
Thanks for the help guys....ill do what u said!!!
