Air Fuel Gauge Stuck On Rich (green Led)
troysevo16
96
Jul 29, 2004
spencerport, New York
My air fuel gauge has stop responding, and is stuck on a green (rich) Led light that is all it reads it wount bouch and filter through the other cycles of rich and lean, no matter what. I have not looked at the problem in detail yet, just woundering if anyone has had this problem or has a solution to fix it, thanks if you do. ps brand new o2 sensor in the front.
this hapened to mine too, it is on the last green led. my purple wire wich hooks up to the 02 sensor under my passenger floorboard came unpluged. i rewired it back and now it works fine.
Check both ends of the signal wire. At the gauge and whereever you spliced it into the O2 sensor circuit for its signal.
