Air Conditioning Fans Wont Turn On
Does the A/C compressor engage when you turn on the A/C if so it sounds like your blower might just be bad. Otherwise you need to check the A/C switch.
There are relays in the fuse box under the hood. Try switching it with one that is the same from another spot and see if it works. Also Does the blower not work only under A/C but works with Heat or just doesn't work at all?
The fans dont work at all, and I'll go try it now.
It's not a blown relay. I think its a blown blower or wiring mishap. But I havent messed around under the dash.
Both fans won't turn on automatically.
From what I know the fan on the passenger side is your radiator fan and is controlled by a temperature sensor.
The other fan, the one on the driver side, is the A/C fan and should come on automatically when the A/C is on, otherwise it should be off.
